charging issue with battery
cichy1012
Year and Model: 1999
Has thanked: 1 time
Post by cichy1012 »
2005 volvo s40 2.5 awd
car died at work had system power message.
friend drove me to store- replaced battery cause battery was 5 years old.
Got home- car gave same message, everything was also shutting down.
Ordered alternator after taking it out and having bench test. - charged new battery
car ran fine from nov 20th till dec 31st.-- car threw same message and shut down.
in the meantime i charged my old battery and installed it; car started up fine.-- alternator was putting out proper voltage as a well as battery and ran about 8 days yesterday - car died again. power message
charged up new battery all night; installed and took car to get tested. battery shows fine as well as alternator.
i used my meter, and with car idle, alternator is putting out 14.8-14.85 volts and batter is putting out 14.7-14.75
could alternator (new) be intermittent bad?
any help would be great. thanks
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
Make sure you don't have a parasitic draw first. Do a proper parasitic draw test.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
cichy1012
Has thanked: 1 time
Post by cichy1012 »
thanks, ill look into that, but why would the car be driving around then start shuttting down functions while im driving. wouldnt the alternator be charging the battery while driving?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Check grounds. Battery and alternator check out but dead battery and you are driving it. Either alternator is not charging, charging but hard amp draw somewhere. Worst case grounds not allowing alternator to charge fully. You can test the battery voltage and alternator output after start up every morning for a week and see where things are at?
cichy1012
Has thanked: 1 time
Post by cichy1012 »
Ok checked Amp draw
Removed negative cable
Put postive amp lead on negative cable
Put negative lead on negative battery post
Result 0.8 amps. Is this enough to cause this ?
Also after I did this test I left the negative off for about 2 hours cause I needed to use the car. I tested the amp draw again and i was no longer showing a drain.
I’m confused
MoVolvos
Post by MoVolvos »
I've corresponded before with both Eric and Charles via email. Really nice and helpful people. As Charles indicated there are more than a couple ways of testing Parasitic Draw. Hope something in these 2 videos will help with your diagnosis.
Richard99
Post by Richard99 »
:evil: no
cichy1012 wrote: 10 Jan 2024, 07:13 Ok checked Amp draw
I’m confused
It’s possible you didn’t let enough time go by to allow internals to shut off completely.
Eric
2000 Volvo V70XC
