Hi Everyone, Happy New Year to you.
My air suspension has come up with service required (2016 XC90 R design), my mechanic at work thinks the compressor has siezed up. He has replaced the compressor with a new one and has a new fuse and relay ready to go in as well (as thats what we read it requires changing as well) but we cant find out anywhere which relay it is to replace in the cargo compartment. The fuse is listed as 40amp in slot 3 but nothing for the relay. Does anyone have any ideas on this location, and the procedure once its changed to get rid of the air suspension service light please?
Many thanks, Andy
Air suspension compressor relay
SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 55 times
- Been thanked: 28 times
I located this diagram on the web. I can't read it, but perhaps this may be of help....dunno.
https://sicherungskasten.info/die-siche ... 2008-2014/
Thanks Jim but unfortunately that one is for the mk1 (upto 2014) not the 2016 model. It’s tough to find anything on it or the correct procedure for fitting a new one and if anything special needs doing. Thanks for your help though
- xiaofei204716
- Year and Model: XC90
- Been thanked: 2 times
This common fault can be solved by replacing the compressor fuse and compressor.
- 1768 Views
Last post by erikv11
- 600 Views
Last post by vtl
- 4468 Views
- 4385 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
