XC60 2015
Treeangel
Year and Model: XC60 2015
Post by Treeangel »
Simple question, when the car is turned off for the evening should you close everything like the fan? A friend used my car last night, parked it and turned off or closed the fan. We experienced below zero temps last night, and when I turned the car on, open the fan so heat can blow, it was making a sound. I personally never close the fan.
Thanks
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 55 times
Been thanked: 28 times
Post by SOURDOUGHJIM »
Sub-zero temps bring out the worst in machinery. My Volvo isn't as new as yours but I just leave the HVAC on auto and turn off the a/c button. When I start it again, the settings stay the same.
JFoley
Year and Model: 2015 XC60
Has thanked: 2 times
Post by JFoley »
I have 2015.5 XC60 T5 and never turn anything off when I shut off the car, hot or cold.
Agree, sub-zero is tough on everything.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Treeangel wrote: 14 Jan 2024, 09:28 Simple question, when the car is turned off for the evening should you close everything like the fan? A friend used my car last night, parked it and turned off or closed the fan. We experienced below zero temps last night, and when I turned the car on, open the fan so heat can blow, it was making a sound. I personally never close the fan.
Thanks
Makes no difference. When you turn on or off the car the fan energize or de-energize. When you turn the fan switch on and off it's the same. You happenstance to catch the fan at a bad moment that's all and it's telling you it's not as healthy or new as it use to be.
