2003 s40 door not closing
S40guy123
Year and Model: 2003 s40
Post by S40guy123 »
I just recently bought a 2003 s40 and the door will not latch! This is causing the battery to die every night which requires a jump start. Does anyone know of a fix for this issue?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
S40guy123 wrote: 17 Jan 2024, 17:59 I just recently bought a 2003 s40 and the door will not latch! This is causing the battery to die every night which requires a jump start. Does anyone know of a fix for this issue?
All door have a two stage latching function. The first grabs the door and leaves a gap then the second is when the door is fully engaged and shut tight. Are you says you've been driving it with the door semi-closed?
S40guy123
Post by S40guy123 »
Short answer yes. But I have a second vehicle im using now. Do you think this fix is possible via my home mechanic skills or will I need a new lock system?
