Hi,
I am wondering if you all might have some advice on how to find OEM hoses for my oil cooler. '99 S70 GLT
As you know Volvo has discontinued these hoses. 9496492 & 9496493
The URO replacements go every year almost on the calendar date. I suspect they are just plain empd rubber without the resistant liner that the originals have.
They dry rot and crack right at the stress point of the fitting and hose clamp.
I would love to replace them with silicone but finding someone to create them is proving difficult.
I had the idea of putting a kind of silicone sleave over the pipe fittings to provide some resistance to coolant breakdown but that seems kind of problematic.
Is there another model that might have a hose that could work?
Have you had to deal with this issue?
Any ideas?
Thanks for considering!
-Eric
P80 Oil Cooler Hose Replacement Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'd go to a heavy / fleet truck parts place, and ask them about it. Large trucks have lots of high pressure hoses to deal with. We have a local place like that, and they make the hoses onsite. It's been awhile since I've had to do it, but they might even use your metal ends; just recrimp with a new collar.
1999 V70 GLT
1999 V70 GLT
- ericmci
- Year and Model: 1999 S70 GLT
- Has thanked: 73 times
- Been thanked: 15 times
My car just has the rubber hoses without fittings that are clamped on the pipes. They have a few S curves in them to route it but it would be nice to have the longevity of silicone over the crappy aftermarket.
The IPD diagram is here- https://www.ipdusa.com/products/21333/E ... HwEALw_wcB
Nice looking 850!
Nice looking 850!
- Has thanked: 2205 times
The -92 only seems available from URO. The -93 still seems available from Volvo. The shorter hose I would look for generic oil resistant hose. If you are concerned it may collapse, you could see if you can find a spring to fit it on the outside of the hose to help it hold it's shape.
- ericmci
That's an interesting idea.
The -93 is still available but now listed as a legacy part so whatever stock is left now.
Hoping to future proof it.
for the shorter maybe a short cut of flexible silicone as it doesn't have to bend in as many ways as the - 93?
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
URO is trash.
Not sure if there's a way to convert to the later hsoe design that's still available new, but it's probably worth looking into.
Foir a cheap and dirty solution, you could try cutting the hardlines on each end, flaring them, and replacing the center rubber part with a good quality hose and clamp it on.
You can also try to see if there's a tractor or power equipment supply place around you that makes hydraulic hoses for tractors - they may be able to make some custom ones for you.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
When I did the RN oil pan/cooler install on my '97 T5, I wound up just using generic 5/8" high-temp silicone hose for the -92 one.
When I need to replace the other original, they make a u-bend that'll work. For your instance, a u-bend and a coupler to a section of straight would be fine if it needs to be longer.
I don't remember which water pipe I used on mine (I had a P80 RN and P2 ones), but my pan was from a P2R motor.
These hoses move coolant, so unless you're drenching them in oil from a leak, there should be no issues.
Mine has been this way for about 3-1/2 years and almost 20K miles.
One of the 2 P2 later versions is also NLA!
- 2163 Views
Last post by fitz548
- 1609 Views
Last post by SuperHerman
- 17 Replies
- 6038 Views
- 1445 Views
Last post by volvolugnut
- 1128 Views
Last post by MDK
