What is most likely, cracks in the soldering on the ABS control unit on the 850 or ABS pump?
Have managed to get 3 error codes on Volvo 850 -96 via OBDII (ELM327)
ABS-313 LRear wheel sensor open/short
ABS-314 RRear wheel sensor open/short
ABS-443 Pump motor fault
I don't want to disassemble the control unit in sheet metal if there is a fault with the ABS pump, without the 443 fault I would have been more sure of only the wrong control unit.
ABS Pump or Controller on scanned 850 ?
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
For Control Unit my voice at least.
Pump has larger power connecter which solders just goes absolute horrible condition after aging and thermal plus vibration cycles if not yet ever opened and fixed.
I seen personally multiple times pump code with cracked abs units on 850 along with sensor codes.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
I was commenting to another poster that the ABS on my '93 makes a very brief scrapping sound shortly after starting up and driving but works fine and gives me no codes, You mention the condition of the solder joints in the control unit and it got me to wondering if maybe the scrapping I'm hearing is the pump not getting the full current it needs due to weak solder joints. The control unit is original with about 200K on it.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Pumps rarely fail, cold solder joints on the control unit are a sure thing.
If it is a brief sound at 10-15 mph on first acceleration after key off, that’s the normal system self-testjmartin919 wrote: 04 Feb 2024, 19:33 I was commenting to another poster that the ABS on my '93 makes a very brief scrapping sound shortly after starting up and driving but works fine and gives me no codes, You mention the condition of the solder joints in the control unit and it got me to wondering if maybe the scrapping I'm hearing is the pump not getting the full current it needs due to weak solder joints. The control unit is original with about 200K on it.
jmartin919
That's what it is. Thanks
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
I’ll guess 990:10 control unit to pump failures on the P80 chassis
- Has thanked: 311 times
- Been thanked: 817 times
I'll go 992:8
- 604 Views
Last post by erikv11
- 26 Replies
- 6453 Views
Last post by bmdubya1198
- 25 Replies
- 5248 Views
Last post by razorx
- 2475 Views
Last post by bigty69
- 4456 Views
