I replaced the purge valve to get rid of a P0447 and doing it didn't help but I should have also replaced the smaller bottom hose that points downward and attaches to (apparently) a hose that is definitely a harder plastic material. (It leads down the side of the fan).
** What size of hose should I get to replace this small piece (maybe 4-5 " long) -- what diameter should I ask for?
** The larger hose to the left seems to be fine.
** If replacing the hose doesn't get rid of the error, what is (generally) the next move?
The car is driving ok -- no bad starts etc but did notice a slight reduction in mpg and overall power it seems. (typical)?
Not a mechanic just the guy who's owned the car since 98. -- many thanks
98 S70 T5 -- purge valve hose size
- npexcept
- Year and Model: XC90 I D5 (275) 2003
- Has thanked: 9 times
- Been thanked: 24 times
Which hose do you mean? Is it in this picture?
This is taken from a diagram for an B5234T3 engine (2.3L, 176 kW; 236 hp, 240 ps).
Is this your engine?
Just because you're trash, doesn't mean you can't do great things.
It's called garbage can, not garbage can not.
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
Number 7. Mine doesn't couple to another part it just attaches to that one long tube. My engine is 2.3L
It's just a short piece of flexible tubing that attaches to the non-flexible one. need to know diameter to buy because it was pretty fraid.
just want to hit the autozone for it?
- npexcept
couldn't find the diameter for that, maybe someone on here can measure it on their car.
But for $3 I'd just order the OEM part (3531116)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Just search for some vacuum elbows which would fit to your vacuum line at any autoparts store.
Those elbows are universal parts for a lots of car brands and are used for many applications like vacuum solenoids,sas system,evap system,pcv system,fpr...etc.
https://www.ipdusa.com/products/5321/Va ... 62-9125615
Just stay away from anything branded URO!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I have had good results with silicone tubing to replace some of the old rubber elbows and nylon hard lines in the purge/evap system.
mar601
Now I see a diagram where what I thought was the purge valve is actually called the solenoid valve (which is the one I replaced). I'm getting a P0447 error and new "solenoid" valve didn't help. Am I reading this diagram right? Does the purge valve also fail? There's also a check valve I see that follows the solenoid valve. -- thanks
edit -- heck with it, it sounds like the P0447 doesn't affect performance. will just blow it off for now,
- 365 Views
Last post by mar601
- 2041 Views
Last post by jakesvolvo
- 13 Replies
- 6908 Views
Last post by VolvoBoron
- 2184 Views
Last post by sleddriver
- 7364 Views
Last post by Seaway
