Volvo v70n 2000 doesn’t fire injectors
Strimis10
Year and Model: Depends
Post by Strimis10 »
So my volvo v70n 2000 (b5244t7) doesn’t fire the injectors, it has spark and fires on starting fluid but the injectors doesn’t get the signal to fire. They have 12v on one of the cables and 3v on the other but it never goes to ground…
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
might be the injector relay under the hood, #8 i think.
you need the circuit diagram for your car.
Strimis10
Post by Strimis10 »
Where do i find that?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
You should ask in P80 forum.
I posted my 1998 V70 fuse/relay location in forum years ago.
Here it is...
You probably have the classic fuel relay of the P80.
You can jump the terminals at the relay CONNECTOR, if car starts, then bad relay.
Strimis10
Post by Strimis10 »
But I don’t have a p80, i have a v70n, the a little newer generation…
jonesg
Post by jonesg »
Strimis10 wrote: 12 Feb 2024, 06:59 Where do i find that?
google or use the search function to search these forums.
