2002 V70 (Driver Side Turn signal bulb)
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Just went out to replace my turn signal bulb thinking it would be a piece of cake but it looks like I need to remove the airbox to get better access. Is this the case? I could not get in there with a pair of needle nose pliers.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
spray the 3 rubber feet holding the airbox, reach down and snap each foot upward one at a time, unscrew the 2 torx screw holding the maf.
its easy peazy to remove the box.
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
No need to remove the maf, the lower piece would do. The upper will just be a minor annoyance.jonesg wrote: 14 Feb 2024, 18:55 spray the 3 rubber feet holding the airbox, reach down and snap each foot upward one at a time, unscrew the 2 torx screw holding the maf.
You can easily reach the bulb without removing the airbox. Maybe it's because I have skinny hands.
Mr. Detail
jonesg, spray with what I will assume to be a can of WD-40?
chris11211, yes you must have small hands. Not sure about easily reaching that bulb.
- 9425 Views
Last post by Turbo_Boss
- 591 Views
Last post by dosbricks
- 452 Views
Last post by oragex
- 2940 Views
Last post by Taskmaster
- 777 Views
