I thought I would post this quick way to change Volvo Subframe Bushings using the Schwaben E36 trailing arm bushing tool. This is available from ECS. If there are no rules against links I am happy to post it but you can search the name on google and find it.
I'll let the pictures do most of the talking. Just make sure you lube the threads really well with anti-seize or something similar. You can use this tool to push out the old bushings and press in the new ones. I have never tried this method with the subframe in the car but I'm sure it would still work. Hope this helps! New bushings made my car feel brand new.
NOTE: In the install pictures below, the subframe is upside down.
Subframe Bushing DIY using E36 Trailing Arm Bushing Tool
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
An E36 BMW tool, interesting. Someone here on MVS recently 3D printed a tool to fit the bushing, I'll have to find that. They posted the 3D files so you can make your own.
Srini850
- Year and Model: 1997 Volvo 855R
Nice! Please post it if you find it. I'm sure that piece would make this tool perfect. However, you can definitely get it done with just this tool. You just have to make sure it is centered and continues to stay centered as you push it in.BlackBart wrote: 20 Feb 2024, 13:39 An E36 BMW tool, interesting. Someone here on MVS recently 3D printed a tool to fit the bushing, I'll have to find that. They posted the 3D files so you can make your own.
I did freeze the bushings before hand but not really sure how much it helped since I did this job in a cold garage in winter.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Not sure many will have that kind of access with the full subframe out of the car?
I found a Harbor Freight electric impact to work quite well. Agree on keeping them straight and square to drive them home—cracked the plastic on one that got just a little bit crooked, even with grease on it.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
I found that you will have a very hard time getting the bushings in straight by just pressing them, but you can get them straight(er) when applying some good blows with a big rubber mallet. With the preload of the press, they should go in nicely.Krons wrote: 20 Feb 2024, 20:55 I found a Harbor Freight electric impact to work quite well. Agree on keeping them straight and square to drive them home—cracked the plastic on one that got just a little bit crooked, even with grease on it.
The E36 tool looks good, but it still squishes the rubber crown. With the 3D printed tool, the E36 tool would probably work perfectly.
(And yes, I'm the guy who made the 3D printed tool, so I might be biased
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
- Krons
A mallet didn’t do anything for me, as I was on jackstands with limited clearance. I just got the bushing snug against the subframe to verify it was square—then drive home with the impact. I got in a hurry on my last one that was just a little crooked.crasbe wrote: 24 Feb 2024, 01:44I found that you will have a very hard time getting the bushings in straight by just pressing them, but you can get them straight(er) when applying some good blows with a big rubber mallet. With the preload of the press, they should go in nicely.Krons wrote: 20 Feb 2024, 20:55 I found a Harbor Freight electric impact to work quite well. Agree on keeping them straight and square to drive them home—cracked the plastic on one that got just a little bit crooked, even with grease on it.
(And yes, I'm the guy who made the 3D printed tool, so I might be biased)
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 2445 Views
Last post by Kazthebassman
- 12565 Views
Last post by ggleavitt
- 720 Views
- 834 Views
Last post by xyourobob
- 11 Replies
- 10499 Views
Last post by BlackBart
