2001 S60 cranks but doesnt want to start (hesitates?)
Rait
Year and Model: 2001 S60
Post by Rait »
Hi, im having a issue with my 01 s60 that just doesnt want to start. It ran fine couple of weeks ago but now it just cranks but hesitates to start, even tried with some starter fluid and got nothing. When i started diagnosting i found that i had around 11 psi of fuel pressure in the fuel rail, changed to filter nothing changed, changed the pump and kaboom we have fuel pressure again (around 47psi after priming) but still doesnt want to start. Tested the spark plugs and coils but they were all fine, changed the spark plugs because they were pretty dirty and old already which i had to change anyway. Compression test was a success aswell nothing wrong with that. Connected my scan tool and got nothing, went over every single one of the fuses and relays but they were all fine aswell.
Pretty sure it cant be the crank/camshaft pos. sensor cause the rpm gauge responds when cranking so it feels like im running in circles at this point.
Added a video what my situation looks like while cranking.
volvo.mp4
(18.64 MiB) Downloaded 244 times
This video is not mine but i got permission to use it, my situation is pretty much exactly the same as shown in the video.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
try unplugging the maf.
could be a big vacuum leak.
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Stupid question, but could it have tripped the immobilizer. You need to unlock and relock the drivers door a few times to reset it. I did this once on my car after cleaning the MAF with maf cleaner.
2008 S60 2.5T Auto (Sold)
Rait
Post by Rait »
Got a new maf sensor and still nothing, same thing with the starter.. got a new one popped it in and still the same exact problem.. At this point im just gonna call up a shop and see if they have some time in the near future to diagnose it cause i cant be asked anymore, im running in circles atm :D
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
It sounds like a fuel issue. The dash shows that you barely have any fuel left. Try adding a few gallons and priming a bunch of times. Also, your battery may be low due to cranking it so much, so try charging the battery or jump-starting the car.
2002 v70 X/C 288k miles
