How do I replace the coolant overflow hose in my 2010 V70?
I noticed that the tube that runs to the top left side of the coolant reservoir is kinked. I purchased a new hose, but I can't see how to remove the old one. Any suggestions? Also, how to install the new hose?
Replacing coolant overflow hose in 2010 V70
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
If you are talking about the hose from the reservoir to the cylinder head.
Reservoir end you squeeze the ears and pull off the hose.
Cylinder head side you squeeze the connector and pull off the hose.
For the other hose that goes to the radiator...........I can't remember but it is similar to what I wrote above.
Good Luck
Paul
Good Luck
Paul
- 928 Views
Last post by Cees Klumper
- 1846 Views
Last post by ndphotonl
- 895 Views
Last post by 93Regina
- 994 Views
- 2800 Views
