2004 XC70 intermittent left/right headlight failure
aaronlife
- Year and Model: 2010 Volvo XC60
- Has thanked: 1 time
- Been thanked: 2 times
I noticed this past week that the headlights started going out while driving. If I wait, they will come back on, sometime quickly, or sometimes it takes a little longer, and I've stopped waiting. I discovered if I switch the headlights off and then back on they work again. When they go out, I get a multiple bulb failure warning on the dash. Any ideas? Inspection is this week (March 1). I was thinking of leaving the headlights off, because they work fine as soon as they are turned on, high and low beams, but I am hoping to figure this out. Was thinking maybe it's a relay issue? I thought that bumps in the road triggered the lights to go off, and then on, but then noticed it happened on a smooth road. Thanks for any advice!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Oxidation/heat damage in sockets. I fixed one temporarily by wiggling the contacts with a small screwdriver, but eventually need to replace the harnesses. They are cheap, like $10-15 on Amazon. Need to cut and crimp/solder.
vtl
All 4 bulbs are controlled by separate fuses. Low and high beams likely have a separate relays. Both low and high going out at the same time is very unlikely.aaronlife wrote: 27 Feb 2024, 09:24 fyi, both left and right go out simultaneously, and the high and low go out at the same time
How do you verify that both go out? It's either low or high beams are on at the same time.
aaronlife
switching between high low on the stalk while my wife stood in front of the car, she said neither worked. only parking lights stayed on.
i'll have to drive the car tonite and play with it again and verify.
vtl
Trace ground wires from all bulbs, they perhaps joined together at some point and attached to the chassis. Loose connection or wire chewed by rodents may cause all bulbs quitting simultaneously.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I had my high beam relay fail and make both high beams intermittently work. On one of my low beam lights, the plastic on the wiring connected to the lightbulb was coming off and shorting. Wrapping the wire in electrical tape and replacing the lightbulb fixed it. You may also have a blown fuse, but for some reason, I didn't have one.
2002 v70 X/C 288k miles
- 1119 Views
Last post by 850oldschool
- 614 Views
Last post by myname
- 334 Views
Last post by aaronlife
- 1806 Views
Last post by enotslim
- 1204 Views
Last post by Stravlr
