2000 S70 automatic transmission failure. Hello everyone, when the gear lever is in the Drive position, my car does not want to stop at traffic lights even though I press the brake, the engine is almost forced to the point of stopping, it wants to go, I have to put the gear lever in neutral. Then, it becomes very difficult to take off, the gear shifts are very early, I switch the gear lever between other positions a few times and sometimes it works, but after a while the malfunction repeats. I don't know if it has something to do with the malfunction, but the cruise control does not work either, and when I connect it to the diagnostic device, no error codes appear regarding these malfunctions.
I need help with this malfunction. What should I do? Which parts should I check?
2000 S70 t5 automatic transmission failure
- misha
- Has thanked: 155 times
- Been thanked: 432 times
To access TCM on post '98 p80 cars you need Vida Dice.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
If want read, clear codes or reset adaptation.. in TCM 99 Volvos and forward ELM327 v1.4b is enough to access CAN Bus. Costs cup of coffee.
But in seriousness i assume hydraulic converter having some issue if its locked constantly or some solenoid can have issue. But not being expert on this.
Some issues here too been.
viewtopic.php?t=16227
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Did you ever replace the transmission fluid? If not, it might help.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- can
- Year and Model: 2000 s70 2.0 t5
- Has thanked: 23 times
I changed the transmission fluid, the problem seemed to be solved, but after a while the same problem occurred again.Clemens wrote: 10 Mar 2024, 15:59 Did you ever replace the transmission fluid? If not, it might help.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Taking a guess as I don't know how the throttle communicates with the TCM. Mine is a 2000 S70 SE Base so no turbo. When I had a stalling issue coming to a light it turned out to be a dirty ETM. After cleaning no more stalling.
- 741 Views
- 1453 Views
Last post by FlyingVolvo
- 1169 Views
Last post by Krons
- 1529 Views
Last post by famfeld
- 837 Views
