I have an error code p0305. What does the following scan readings mean.
Calc load 12
Ectf 204.8
Stftb1 0
Ltftb1 3.9
I know it is cylinder 5.
Installed new plugs.
Assistance Appreciated!
P0305 code 96 850
- Has thanked: 2203 times
Check you are getting spark to the cylinder.
Check the spark plug boot is connecting the plug correctly.
Check the plug gaps are 0.028"
Check the distributor cap and rotor for damage and wear.
Check inside the distributor for leaking oil internally.
Last thing, check the cylinder compression. Low compression may mean a burnt valve.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.2forty wrote: 12 Mar 2024, 19:59 I have an error code p0305. What does the following scan readings mean.
Calc load 12
Ectf 204.8
Stftb1 0
Ltftb1 3.9
P0305 Code Demystified — Cylinder 5 Misfire Detected
https://eeuroparts.com/blog/p0305-code- ... -detected/
My P0304 turned out to be the #4 injector. I started with the plugs and coils then fuel. Hindsight it's the easiest to check the injectors first.
viewtopic.php?p=642607#p642607
- 93 Replies
- 28745 Views
Last post by foggydogg
- 13 Replies
- 3650 Views
Last post by jerseykat1
- 1239 Views
Last post by blomkvist
- 2015 Views
Last post by jtp
- 1722 Views
Last post by FLXC90
