2008 S80 Power Steering Pump noise
Robranger714
Year and Model: 2008 S80
Post by Robranger714 »
I recently replaced the power steering pump and filled/bled it with the proper fluid. It is still making noise. It sounds like the noise is coming from behind the pulley, where a spring loaded pulley (?) is behind it. This thing has 2 alignment pins that the power steering pulley lines up with. What is this thing and why can't I find one online?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
The reservoir has a built in filter in the bottom.
Did you replace the reservoir?
https://www.freel2.com/forum/topic31501.html
Volvo Engine Water Pump Coupling - Genuine Volvo 31219096
Good luck
Paul
