Key locked inside the car, 2nd remote not unlocking Topic is solved
weitau
Year and Model: 2004 V70
Has thanked: 7 times
Been thanked: 2 times
Post by weitau »
So the other day, my V70 was in the driveway with the engine running. My significant other locked the doors (perhaps it's because we live in NYC, we don't trust anyone). She used the second remote we have, but it would not unlock the doors. I used the physical key to unlock, but the lock cylinder would not turn. Eventually AAA came and they used a tool to pull up the door lock knob inside.
With the engine off, and me standing outside, I tested both remotes. They both work as expected. :o
Are Volvos designed to do this? disable other remotes when one remote/key is already in the ignition?
Full disclosure, my "Alarm needs service" light is on, I pulled the alarm fuse, sunroof works. The remote battery was low, but replaced when I was attempting to unlock.
2004 V70 2.4L
weitau
Post by weitau »
BTW, I called Volvo and they don't have any idea if this was normal. They suggested towing to the stealership. But they'd tow it there for free due to their "Lifetime free tow" owner benefit. This was new to me, but I'd never have it towed to the dealer unless I'm looking for pain.
2004 V70 2.4L
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
yes thats normal....almost.
i don't know how you managed to lock the car from outside with the engine running.
with engine running it should not respond to second fob.
the solution is don't do it.
btw, if your engine is running you can also call the fire dept, its a fire risk.
my cop neighbor told me.
weitau
Post by weitau »
lol, you can be sure it's not going to happen again.
still, I'm confused why Volvo would do this? maybe useful in a marital conflict?
2004 V70 2.4L
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
You can do this experiment again and report back.
Do it with the driver's glass lowered and:
- Engine off
- Engine running.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
weitau wrote: 24 Mar 2024, 21:45 lol, you can be sure it's not going to happen again.
The vehicle detected New York City and found no gun in the cabin. For the passengers safety let itself locked with the engine running.
jonesg
Post by jonesg »
cn90 wrote: 24 Mar 2024, 22:33 You can do this experiment again and report back.
- Engine off
- Engine running.
its in the owners manual, you cannot engage security system with a second key whilst the engine is running.
I had a fob that kept locking the doors when I was working on the car (engine off),
I had to leave the window down, turned out to be the fob battery was going south.
Installed a new battery and it never happened again.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
vtl wrote: 25 Mar 2024, 11:08
The comment might be bordering on the off limits topics list. However, that kind of alien software is being developed but firearms are considered illegal and dangerous in NY.
brobert
Year and Model: 2006 V70
Has thanked: 9 times
Been thanked: 13 times
Post by brobert »
Another simple thing to check:
With the key in the ignition (Pos 0) and door open, does your chime (ding-ding) activate?
If you cannot hear the chime, the CEM is not detecting a key in the ignition.
That signal is important as it prevents you from locking the doors with a key in the ignition.
This seems to be where your problem started.
/BR
- Engine off
- Engine running.
weitau
Post by weitau »
brobert wrote: 25 Mar 2024, 18:19 Another simple thing to check:
/BR
OK, with key in ignition Pos 0, the chime comes on when the door is open.
I can close the door, and manually lock the door with the door knob. This is what I'd normally expect when driving away (while you're inside). I think my wife used the door knob, locked the door while it was open, then closed it.
Which gets to the next message:
2004 V70 2.4L
