Flare nut size for brake lines
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I am replacing all of the brake lines on my 2002 V70 XC. I will also replace the brake fluid during that time. Are there any special tools I would need other than flare wrenches and something to bleed the brakes with? Are the flare wrenches required? I read on this site that an 11mm one is used for an older 850. It seems that the stores near me have all sizes except for 11mm. Is this size needed for my volvo?
2002 v70 X/C 288k miles
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Yes, use flare nut wrenches. A metric set is worth having and should have all the sizes. They have a different size on each end.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
That's brake hoses =) Lines are made of stainless steel if I'm not mistaken.02V70 wrote: 23 Mar 2024, 20:00 They were cracking and users of MVS said to replace them
viewtopic.php?p=629695
I used just regular wrenches, but flare ones would be easier.
- Been thanked: 504 times
Propane torch is useful.
Front hoses are not too difficult
Rear hoses can be a nightmare at both ends (where it is attached to the metal lines and at the caliper itself)...so if you don't have to replace the rear hoses, leave them alone.
- 12 Replies
- 4577 Views
Last post by theWIFES_S70
- 14 Replies
- 2376 Views
Last post by MoVolvos
- 1090 Views
Last post by zombielinux
- 13 Replies
- 3975 Views
Last post by volvolugnut
- 1953 Views
