1/13/2024 242,776 - Timing belt, water pump and components replaced, coolant replaced. Front struts replaced.
1/14/2024 242,820 - Oil and filter changed, repaired vacuum hoses
2/3/2024 242,836 - Wheels and tires replaced ("Argo" 15" Volvo alloys installed with Yokohama Sport Touring tires). Front brake pads replaced. Alignment performed.
2/5/2024 243,096 - Repaired odometer and set correct mileage.
2/9/2024 243,101 - Replaced battery positive cable bolt, cleaned all battery connections. Replaced blower motor (Continental/VDO). Replaced rear brake pads. Replaced rear shocks and shock mounts.
2/19/2024 243,281 - Serviced PCV system, verified block ports are clear. Serviced EGR system, cleaned EGR valve and port in intake manifold. Replaced all 5 fuel injectors with rebuilt units from 1996 850T engine. Cleaned throttle body. Replaced vacuum hoses.
2/25/2024 243,363 - Replaced front oxygen sensor, heater core, heater firewall coupler and hard lines. Soldered in new injector relay wiring at radiator fan shroud. Installed auto-dimming mirror from 2004 C70. Changed oil and filter. Replaced thermostat, re-mounted radiator. Replaced spark plugs.
3/1/2024 243,404 - Blower motor controller replaced. Fuel pump and filter replaced (Bosch assembly). Radio replaced (SC-816 from 2000 S70 with 1997 960 SC-816 faceplate)
3/6/2024 243,407 - Replaced camshaft position sensor, injector relay, fuel pump relay.
1994 855 Turbo Rolling Restoration - Honey Badger
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
