‘07 S80 3.2 167K — Suspension Feeling a Little Floaty
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
First P3 we’ve owned. Bought at 125 K. Got very comprehensive service at 150K. I don’t drive it frequently. It needs brakes and I noticed the ride seemed a bit “floaty” recently. If I do a suspension refresh, what should I be looking to change? I have the non-electronic suspension.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2652 times
- Been thanked: 1242 times
Left to right floaty or up and down floaty?
- E Showell
Great question. Seemed like up and down to me. Very stable left to right.
'95 855 auto (sold)
'95 855 auto (sold)
It'd be hard to say the floaty feeling is anything but struts/shocks... just worn out.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Around 5 years ago my Son and I test drove one with100K and the owner had already changed the front units. Can't remember whether the rears were changed but the new fronts were squeaking. Best to change front and rear as the bad side will compensate / work harder for the other end when floating / bouncing.
They are similar to P1 as the strut is inserted into the steering knuckle and pitched by a single bolt rather than the standard 2 bolt strut. While you're in there check the wheel bearings, tie rods, control arm bushings and sway bar links. Replace the strut bearings and inspect the strut mount. The strut bearing looks identical to the C30 in terms of design but the strut mount is different and doesn't seem like it would easily go bad?
The control arms are also similar to the C30 except for the front bushing.
Volvo Strut Kit - Sachs KIT-524264
https://www.fcpeuro.com/products/volvo- ... -sachs-kit
Volvo Control Arm Kit - Lemforder 31317661KT1
https://www.fcpeuro.com/products/volvo- ... -p3cakt2p6
