Faint, single "pop" sound when taking off
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
When pulling forward from a dead stop, there is a faint, single "pop" sound that I'm hearing/feeling. Doesn't happen every time, but it's definitely there. Wondering if it could be one of the various motor mounts. Thoughts/suggestions?
hu5ker555
Interesting...it also does feel like there is just a little more slop in the front end, for instance when I'm turning into my driveway and going over the curb cut. Otherwise, it rides and feels great.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
A good possibility with some worse than others.
Axle Bolt with Rubber Insulator (Anti-Ping) Front
https://www.ipdusa.com/products/6251/Ax ... o-30670602
- MoVolvos
Or this? One of the more difficult to find noises. Installed these on our 03 S80 T6 with success.
Subframe O-Ring (Addresses sub-frame knocking noise)
https://www.ipdusa.com/products/8283/Su ... vo-8638585
- RickHaleParker
- Been thanked: 977 times
Open the hood, fix eyes on strut mount, bounce car up and down.hu5ker555 wrote: 09 Apr 2024, 13:33 When pulling forward from a dead stop, there is a faint, single "pop" sound that I'm hearing/feeling. Doesn't happen every time, but it's definitely there. Wondering if it could be one of the various motor mounts. Thoughts/suggestions?
Is the rubber on the strut mount broken?
Active
Past
Past
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Sorry actually instead of just strut mounts I was going to say strut bearings. Mine are for sure bad(well the one, I've replaced the other one).
Couple of years ago = couple of years too many now. It's time probably. But also, there is one small rubber pad(also called spring seat) on which the strut spring lays(lies?), if it has disintegrated, which I am sure happens after years, the spring can come into direct metal to metal contact with the strut spring seat.
- 1237 Views
Last post by Thenextman
- 1827 Views
Last post by xHeart
- 513 Views
Last post by jonesg
- 552 Views
Last post by Georgeandkira
- 2528 Views
Last post by AVOIT17
