2012 S60 T5 misfire problem
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
usawsn
Year and Model: 2012 S60 T5
Has thanked: 1 time
Post by usawsn »
Car is about 111k miles. My wife was driving to another place and saw the check engine light after 1.5 hours drive. She went to Autozone near Vernon, CT and was told there was misfire on cylinder #4. Then she went to a close-by Jiffy Lube store.
The tech at JL changed all the spark plugs to NGK and told my wife it would be okay, but the issue came back right after a couple of minutes of driving. She had to go to another place so she left the car there.
Today, Jiffy Lube purchased another set of spark plugs and also replaced the ignition coil. Problem remained. They said they couldn't do compression test. I will have to figure out a way to tow the car back to my home (about 80 miles in MA). I joined AAA plus but that can only be used after 7 days. Is it possible to use that a couple of days before the 7 days?
Hopefully it is not the engine issue, although it is quite likely. We used premium gas (#93) for years, but last year my wife decided to use #87. It has been okay since then. Yesterday before the long drive, I filled up with #93. Could this be a cause or trigger?
Also, the car has been burning oil since about 80k miles. Recently, the rate is about 1 quart per 1000 miles.
Thanks for any input.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
usawsn wrote: 11 Apr 2024, 15:00 Car is about 111k miles. My wife was driving to another place and saw the check engine light after 1.5 hours drive. She went to Autozone near Vernon, CT and was told there was misfire on cylinder #4. Then she went to a close-by Jiffy Lube store.
Mine turned out to be the injector.
viewtopic.php?p=642601&hilit=Replaced+a ... or#p642601
usawsn
Has thanked: 1 time
Post by usawsn »
MoVolvos wrote: 11 Apr 2024, 15:36
That is a good suggestion. One more thing to check. Thanks.
usawsn
Has thanked: 1 time
Post by usawsn »
Could you help confirm the parts? Based on the VIN#, the engine is: B5254T5. I was searching the dealership parts online but couldn't see the exact keyword: B5254T5. Will the below fit? Thanks.
Spark Plug Set: Part Number: 30751806. For: 2005- B5204T5. 5CYL TURBO. B5204T5, 2005-. B5254T10. B5254T4, B5244T4/T5. B5254T6. B5254T6, B5254T10. Variant code: CF17 or CF6C.
Direct Ignition Coil: Part Number: 30713417. For: 2005- B5204T5. 5CYL TURBO. 5CYL without TURBO. B5204T5 2005- , B5254T4, B5244T4/T5. B5204T5. B5244T4. B5244T4/T5. B5254T4. CH 390000-.
Fuel Injector: Part Number: 30757534. For: 5CYL TURBO. 5CYL TURBO. B5254T12. B5254T12, B5254T14. B5254TX. EXC B5204T8/T9. Variant code: CF9A or CFA5. Variant code: CF9A. Variant code: CFA5 or CF9A.
MoVolvos
Post by MoVolvos »
usawsn wrote: 12 Apr 2024, 06:46 Could you help confirm the parts? Based on the VIN#, the engine is: B5254T5. I was searching the dealership parts online but couldn't see the exact keyword: B5254T5. Will the below fit? Thanks.
Not sure why Volvo not showing B5354T5? Some links below but as not helpful as I like.
Volvo does show 2 injectors for a 2012 S60 T5.
https://usparts.volvocars.com/a/Volvo_2 ... 55907.html
FCP shows Bosch 30757534 2012 Volvo S60 T5 Sedan 2.5L L5 B5254T5 Automatic
https://www.fcpeuro.com/products/volvo- ... r-30757534
Amazon has Bosch number as FCP.
(www.amazon.com/Bosch-Original-Equipment ... B00H2ROK6O)
usawsn
Has thanked: 1 time
Post by usawsn »
Worst news. The car was towed to a local garage and I was told that 0 compression on cylinder #4. They don't suggest any more work on this. An used engine swap could also take 5000+ dollars.
Any other ideas?
How do I even get rid of it now? :(
usawsn
Has thanked: 1 time
Post by usawsn »
I just drove the car back from the shop. The drive was rough but not too bad. I plan to buy or lease a new car.
But before that happens, if I drive the car for a few miles occasionally (one or two times a week) to take my kids within town for activities, what is the risk for doing that for a few weeks?
MoVolvos
Post by MoVolvos »
Unplug the injector so fuel is not being dumped into the CAT.
usawsn
Has thanked: 1 time
Post by usawsn »
With no compression, replacing the fuel injector does not help at all, correct? Just trying to think of the last resort.
MoVolvos
Post by MoVolvos »
usawsn wrote: 23 Apr 2024, 10:08 With no compression, replacing the fuel injector does not help at all, correct? Just trying to think of the last resort.
If the cause of 0 compression is a burnt valve, only a replacement will work. Just pull the injector plug wire so no fuel is being dumped into the cylinder. There are varying opinions on whether one can drive with one less cylinder. Since you have no compression it would seem okay if no fuel is going to that cylinder, although it might affect the downstream O2 due to un-combusted air. Not sure how the software will compensate and in so doing affect the other cylinders in terms of fuel and air ratio.
