1998 v70 t5 Replaced PCV now auto transmission light flashing Topic is solved
Grover365
Year and Model: 1998 V70 T5
Has thanked: 2 times
Been thanked: 2 times
Post by Grover365 »
I just finished replacing my PCV and after starting for first time, auto trans light is flashing and a repeating (not knocking) noise has started. I assume i forgot to plug a sensor or knocked a tube loose. Any Ideas before i pull it all apart again?
thanks guys
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
TPS sensor on throttle body?
Problem is that TCM codes won't go away until read & cleared with specific tool like Vol-Fcr or 850 OBD II app.
You might get away with plugging the sensor and remove battery cables for a few minutes since TPS code is shared with both ECU & TCM.
Could be a knock sensor...but it shouldn't affect TCM.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Grover365
Post by Grover365 »
Update: spent months trying to get a scanner to work myself. 3 ELM OBDII sensors and a Dice Clone + VIDA and nothing. Volvo dealer quoted $400 AUD just to scan. took it to an independent auto electrician today, they scanned diagnosed and fixed it for $450. it was the throttle position sensor, they said it was out of range and are replacing it.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Misha for the win.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
