Climate Control module & stereo dead
B2rT
Year and Model: 2010 XC60
Post by B2rT »
Hello, I have a problem with a Volvo XC60 from 2010 with a 2.4 Diesel engine.
All button on climate control module doesn't work.
I can't change temperature and speed air.
I can't change volume. Only works buttons for choose FM/AUX.
And works on wheel steering.
Also doesn't works remote control for close my car.
The errors what I have:
CEM-U016400
https://www.dtcdecode.com/Volvo/CEM-U016400
CEM-U201F87
https://www.dtcdecode.com/Volvo/CEM-U201F87
PBM-U014000
https://www.dtcdecode.com/Volvo/PBM-U014000
ICM-B102F15
https://www.dtcdecode.com/Volvo/ICM-B102F15
I have access to VDASH and P3Tool, if necessary I can use VIDA.
I looked through the installation and checked all the fuses but found nothing.
Thank you in advance for your tips. Regards
B2rT
Post by B2rT »
I have found problem wrong connection between fuses and socket. If sombody will have problem like me, check your fuses and clean it very good and then you will have no more any problems. Best regards.
jettman
Year and Model: 2015 v60
Post by jettman »
It is good that you fixed your problem. I have the same problem with mine.
Can you share which fuse panel you had a problem with?
Thanks. John
