5 Codes at Once - what gives? P0343, P0243, P0193, P0182, P0181
Nigel
Year and Model: 2001 C70 Convertible
Has thanked: 3 times
Post by Nigel »
So recently I had the CEL come on, and there were 5 codes present.
The codes are:
P0181 - Fuel Temp Sensor A Circuit Range/Performance
P0182 - Fuel Temp Sensor A Circuit Low
P0193 - Fuel Rail Pressure Sensor Circuit A High
P0243 - Turbo Wastegate Solenoid A
P0343 - Camshaft Position Sensor A Circuit High Bank 1 or Single Sensor
I cleared the codes, and they all came back on the next drive.
The car is running mostly like normal, perhaps it is a tiny bit low on power, but that could be my imagination. The similarity here seems to be that all the codes are related to circuit A, maybe there is a short somewhere or a common component in the circuit failed? None of the wires appear to be damaged, so before I go and start replacing parts, I was wondering if anyone had any input on this situation. Thank you Volvo friends.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Check your battery voltage running and after everything off for an hour. Low voltage can cause weird codes. Starting OK does not assure good voltage for other computer functions.
