It started a couple days ago as a flashing light that would go away after about a minute. Now it's a solid light that stays on. Tried the 20 shift tip but that hasn't changed things.
The timeline and symtpoms:
Background: Alternator rebuilt three weeks ago
Flashing transmission light started yesterday. Two trips where it would go out around the same time as the service light. Felt normal afterwards but that was in stop and go traffic.This is when I first tried the 20 shift tip
Today, one trip with the flashing light/ Flashing light went out but it seemed down on power. Wouldn't go past around 2800 rpm. Possibly relevant that this is the first trip this month with light traffic (7kph average on the computer for 100km)
On the way back home it was a solid light that wouldn't go away. Car needed to rev up to around 2k to start moving, once moving it wasn't terrible, but I was just trying to get it home.
I hear the PNP switch is a common failure point but I'm not sure my symptoms are cosnsitent with that. Currently don't have a way to read codes.
98 850 T-5 A/T trans limp mode, maybe also down on power. Topic is solved
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 29 times
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You must read the codes...otherwise it will get pretty expensive.
Vol-fcr with a laptop or 850 OBDII android app is a must.
Your transmission starts in 3rd gear and that's why it needs past 2k rpm to start moving.. it acts the same in winter mode too.
About pnp switch...if you have reverse lights in R...pnp is ok.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RedBrickCollector
So it's possibly stuck in winter mode? I have not been able to get either of those to work, I guess that will be my next priority
'97 950 T-5 Wagon
- misha
Pm xanthefin here on MVS and he will give you all information about his 850 OBDII android app.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RedBrickCollector
Issue was an improperly seated TCM
'97 950 T-5 Wagon
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Another thought might be to monitor your system voltage while driving.
Something as simple as meter plugged into your cigarette lighter may
give you some clues.
