oil thermostat o ring and RTV
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
I'm replacing the oil cooler lines right now. I have everything out and the only part missing for putting it back together is the recangular thermostat o ring. The old one isn't torn, but it is hardening up a bit.
Since the way to put everything back together favors using some RTV to "glue" the o-Ring into its place during assembly I was wondering if I could use a bit more RTV as a second seal layer for the hardenibg O-Ring. Or should I wait till Monday till the ORing arrives at my dealer?
I don't need to drive the car rightaway, but I want to finish the job and have one Volvo off the jackstand.
Opinions, please!
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
I am not a fan of RTV. It can cause corrosion from the acetic acid and the crumbly bits that get loose work their way to other areas and cause problems in valves.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'd wait for the new O-ring. And a little grease on it will keep it in place during installation.
1999 V70 GLT
BlackBart
Been thanked: 884 times
Post by BlackBart »
Clemens wrote: 24 Apr 2024, 06:42 I don't need to drive the car rightaway, but I want to finish the job and have one Volvo off the jackstand.
I know just how you feel. But for that amount of time and work, I'd wait for the new one.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
This makes +4, wait for the Volvo part. There isn't a lot of pressure on the system at that point, but even a little seepage there can make a real mess.
Clemens
Post by Clemens »
4 vs. 1. That's not fair.
So I will be forced to another long haul in my Transit camper van on the weekend.
You are right, it's not worth the risk.
Summer: 1996 855 R
Donor: 1995 854 10V
