Is there any information in some manual how much movement the M90 clutch slave cylinder should have?
Even with the pedal fully depressed and in first or reverse gear there is some slight creep in my homebuilt car and I suspect maybe my slave doesnt get enough throw. (everything between the engine and gearbox is new or in good shape with less than 1500 miles on it)
I would be very grateful if anyone has that information available or can check it on a working car.
M90 clutch slave cylinder throw?
- RickHaleParker
- Been thanked: 979 times
Don't know if it is written some place but stroke is about 18mm - 19mm
falcor75 wrote: 26 Apr 2024, 10:09 Is there any information in some manual how much movement the M90 clutch slave cylinder should have?
Active
Past
Past
