I need to glue a clip back onto a small exterior trim piece, a straight piece under the driver's side rear door.
Looks like someone has already been in there, but their glue repair finally failed.
The back of the plastic is stamped "PP+EPDM+M10" I suspect it is just polypropylene?
Any suggestions for an adhesive that will stick?
Glue for exterior body plastics 06 S60
- Has thanked: 311 times
- Been thanked: 817 times
- Has thanked: 2207 times
JB weld Plastic (black). Roughen the surfaces and mix the JB weld and stick it. Give it 24hrs to set. It does dry in about an hour but but on the surface. Give it 24hrs for good measure. I use that to rebuild broken P80 dashboard mounts.
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
I intend to try plastic welding for such repairs. Given the variety of materials now available it seems there will be something compatible with most common "legacy" plastic. With practice welding seems more likely to be successful and stable long term. Joins that are hidden from view, as in this case, can dispense with some aesthetics.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- Has thanked: 987 times
- Been thanked: 1076 times
PP should indeed be Polypropylene. With addition of EPDM and M10.
See this link for EPDM adhesive:
https://www.permabond.com/resource-cent ... -adhesive/
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Plastic welder on Amazon. Get another donor piece to melt, with the same plastic kind letters.
The reason why plastic repairs fail is different thermal contraction rate of different plastics. If the same plastic was used for repair, the repair will hold forever.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Lots of good ideas in these.
