98 s70 T5 -- coolant pressure test kit
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
I thought of getting a pressure test kit. Can you pressure test the cooling system at the expansion tank? I'm not familiar with other areas of access. -- thanks
If I can do it there, maybe someone can recommend a specific test kit? Would this be ok?
And what window should the pressure be in?
https://www.amazon.com/WNZ-Universal-Ra ... r=8-5&th=1
Has thanked: 2207 times
Been thanked: 1852 times
We can't see the link here. If you have the standard cone shaped tester, you can fit it in the top of the coolant header tank.
If it is an actual pressure tester, then you need the adapter to fit where the coolant cap is. Remove the cap and then screw on the adapter in it's place.
