ISO outer cv boot clamp 850t.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
Found in the archives "outer boot large oetiker 91mm 1025 9mm band". Anybody have a source for these or a handful in the garage??
Thanks.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
belmetric.com/clamp-9mm-band-stepless-ear-oetiker-167-stainless/?sku=CV102.5BAND9
It says the sight is down for maintenance at the moment.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
rguzz
Post by rguzz »
Thanks, site down yesterday up and running so I ordered a few. Proper sizing in the kits, even the "right" ones seems hit and miss.
jmartin919
Great. Let us know how they work out. I need to do the same.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
rguzz
Post by rguzz »
Yes will give f/u after scrutinizing Belmetrics clamps. Feeling optimistic.
rguzz
Post by rguzz »
Got the Belmetric clamps. They are 102.5mm. My newly arrived GKN boot from Autohausaz, which only cost something like 11 bucks, had a 104mm clamp that was not SS. We found the alignment with the barbs on the 104mm clamps to be a bit better fit. If jmartin919, you want a 102.5 I'll send you one for the postage just pm me. It's likely the 102.5's will fit fine, the GKN is thicker than most replacements, but I went with the 104's for whatever that's worth. Thanks.
jmartin919
Finally got around to installing the 102.5mm band (that rguzz sent) on my 2000 S70 GLT SE. The 102.5mm is too big. By my measurement I need a 91mm. Unfortunately Belmetric doesn't have that size.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
You might be able to get a stainless exhaust wrap securing band and use that instead. Just an idea in case you're stuck otherwise. You basically run it through the joint, fold it over, and secure the securing clamps, then clip off the excess.
jmartin919
I have a screw clamp on there now and it's working fine. I'll check out those straps. Thanks.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
rguzz
Post by rguzz »
The turbo axle requires a different sized clamp as you likely know. IIRC the 102.5mm was a great fit for the 96t. If the 2000 is NA it will certainly be different, either way there were weird variations in CVJ size along the way. Sorry my clamp didn't work for you!
