The Truth About Oil Change Intervals And Analysis w/ Lake Speed Jr.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
So back to the old days of 3K miles oil changes or an oil analysis. Really, really informative and the last word on oil from Lake Speed Jr.
Also, good fuel matters. Having used Premium in all my cars longer than I can remember, never had a spark plug or combustion related issue once I got the car to Stage 0.
Lastly, use the appropriate viscosity for the correct ambient temp.
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Good fuel is always a must. Getting a fuel pump clogged or clogging fuel injectors is not worth the price. Plus, remember what ethanol can do over time, as it attracts moisture and water. This can result in rusting of components and a gelatinous type of build-up in the fuel tank.
For the oils, here is a good post about good oils to use in the XC90 gas engines. With the XC90 weighing 300-500lbs more than a comparable S60, the engines go through more load all the time.
https://www.swedespeed.com/threads/oil- ... st-8046070
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
