'05 v70 n/a Surging on acceleration
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I did again and bought another P2, this one an '05 v70 n/a, about 180k and apparently well cared for. At first performance was very power with very low power. Initially I thought this was perhaps a bad coil being similar to a condition I had with another P2, but as I add a few miles, it improves. I still have low power but most noticeable is that on acceleration it surges, losing power then regaining it. At highway speed there is also some surging but much less detectable. It seems to be improving gradually. It is possible that the car sat for some time, the service records end in 2021. I have no idea, does anyone have a suggestion? I am wondering if it sat and gas evaporated in the fuel system leaving residue.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Faust
I have nothing to test it with, nor a code reader. But I do have 2 '04 v70 sitting under my barn, both previously "good runners". So, I can experiment with changing parts.
2004 V70
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
ICarSoft Volvo scanner is $150 on Amazon and worth having.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
SamiMarsden
- Year and Model: 2006 XC70
When my xc70 had weird surging it was caused by a combo of a bad/dirty MAF and my engine air intake box not sealing correctly.
- Has thanked: 311 times
- Been thanked: 818 times
Fuel pressure sensor is a possibility. What vtl said - read the codes.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It's actually live data, but still reachable with a generic OBD-II scanner.erikv11 wrote: 15 May 2024, 23:50 Fuel pressure sensor is a possibility. What vtl said - read the codes.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Faust wrote: 13 May 2024, 20:52 I have nothing to test it with, nor a code reader. But I do have 2 '04 v70 sitting under my barn, both previously "good runners". So, I can experiment with changing parts.
Get a mini OBDII along with the free Car Scanner App. Has worked exceptionally well over the years. The Android dongles are a bit easier to work with than the iOS.
Need to pull codes, if any to provide you with direction. However, after chasing a couple a codes and changing parts on my 00 S70 N/A the car was still a little off.
Not sure if the 05 V70 N/A ETM is similar the 00 S70 N/A but carefully clean the butterfly front and back gently opening it with your finger. Put a cloth under the butterfly as you sparingly spray and wipe all the surfaces.
$9.69 - OBDII OBD2 Bluetooth Car Diagnostic Scan Tool Auto OBD Scanner for Android Devices…
(www.amazon.com/gp/product/B01HXGX8V6/re ... UTF8&psc=1)
Car Scanner ELM OBD2
https://play.google.com/store/apps/deta ... carscanner
swap the fuel pressure sensorsFaust wrote: 13 May 2024, 20:52 I have nothing to test it with, nor a code reader. But I do have 2 '04 v70 sitting under my barn, both previously "good runners". So, I can experiment with changing parts.
Faust
Waiting for week end to change fuel filter and add some Berrymans as recommended above. In the meanwhile, I just threw in a can of dollar store fuel injection cleaner. It has improved quite a bit, although it still seems low on power and surging can be felt when accelerating at highway speeds. Auto tans shifting is also erratic.
2004 V70
- 153 Views
Last post by Krons
- 1219 Views
Last post by IdahoBob
- 1371 Views
- 24 Replies
- 3603 Views
Last post by bmdubya1198
- 16 Replies
- 5247 Views
