S60 2.3 T5 Automatic Asin HP tolerance Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
frostyzen
Year and Model: 2006 S60 2.4i
Post by frostyzen »
Hello,
I'm looking at a 2.3 T5 (2004 s60) this month in Germany. It however has the Asin 50-55 automatic transmission. (presumably, im gonna check)
How reliable and how much torque/hp can this transmission handle? I'm looking to upgrade the intercooler and push past 300hp. Have had conflicting reports on whether the Asin autos take this well.
Anyone have any experience?
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
It's torque, I think it's limit is usually 330nm, but if you are gentle it might handle more. But you will have to never WOT at standstill.
At 300hp you would likely be nearing 400nm.
frostyzen
Post by frostyzen »
330nm? Thats literally what it pushes at stock already?
Are they really that weak? Not looking forward to finding a manual tranny and swapping.
dikidera
Post by dikidera »
Sorry I guess my info was a bit wrong, it has been a while since I was researching this, since the diesel engines came with 330-400nm factory at the time they were using AW55, it should handle the torque then.
https://www.volvoforums.org.uk/showthread.php?t=88142
And maybe up to 450nm
http://nefariousmotorsports.com/forum/i ... #msg156733
The block though can handle much more power so you will be gearbox limited.
frostyzen
Post by frostyzen »
Thats a relief, I was aiming for 300hp at the start and we'll see where the weak points arise and work from there.
Has thanked: 1836 times
Been thanked: 1709 times
My older 2000 R with a tune is supposedly pushing over 310bhp and 300 Nm. In the 5 speed auto in this car it was only rated to 320 bhp for safe operation.
