Blue smoke from exhaust
radek93
- Year and Model: S70 98
- Has thanked: 2 times
- Been thanked: 3 times
B5254t. What does blue smoke from the exhaust mean? It only smokes when the engine is warm, when it runs for several dozen seconds at idle speed and after increasing the speed. It does not smoke when the engine is cold immediately after starting, it does not smoke when accelerating, it does not smoke when engine braking and then accelerating. The oil filler cap is gently sucked on when the engine is running. So PVC seems to work well.
- Has thanked: 2197 times
- Been thanked: 1850 times
The 2 main issues are hardened valve stem seals, or worn turbo seals.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Or wrong viscosity oil(read too thin)..but like Neil said...turbo or valve stem seals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
+1 on the above mentioned options
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Since it doesn't smoke when accelerating that generally eliminates rings, and based purely on age, if the car hasn't had valve stem seals yet, they are likely age-hardened. A suggestion would be to change the oil - follow the recommended viscosity in the owners manual, the folks who designed the car do know best - and see if it has any effect on the behavior. Avoid all the Magic In A Bottle, that stuff is good for draining your wallet and not much else.
- 1759 Views
Last post by erikv11
- 1282 Views
Last post by Canadian850
- 1723 Views
- 2650 Views
Last post by beigg
- 16 Replies
- 3255 Views
