'05 V70 Seat interchange
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
The driver's seat in my car has seen better days and I have thought to search my local junkyard. Just watched a YouTube video where a guy is restoring an '05 V70R, with the same problem. He intended to use the seats from a wrecked '04 S60 parts car he purchased. On trial, they wouldn't fit. He mentions that they had three different (with same appearance) seats in the middle oughts and that they do not interchange. Does anyone know more about this? If I stick with '05 seats will I be OK? Where do the differences lie, I am thinking I could take a measuring tape to the junkyard.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
What specifically is the problem with your seats? If it's just the leather skin I would suggest finding a good donor passenger side skin in the junkyard and using that. They interchange from left to right with the exception of the lumbar knob which you'd have to cut a 1 inch diameter hole for the drivers side. Often the passenger side skin can be found in mint condition. I believe the auto wreckers charged me less than $30 for both the seat and seatback skin last time I bought them. They take 2-3 hours to change.
2003 XC 70 (sold)
Faust
Post by Faust »
I had thought about changing just the skins but thought switching entire seat would be faster and easier.
2004 V70
Has thanked: 1610 times
Been thanked: 4065 times
You need to research the control electronics as there were changes in CANBUS speeds from 2004 to 2005. I don’t know if seats were involved, but the two are not compatible
Faust
Post by Faust »
"You need to research the control electronics as there were changes in CANBUS speeds from 2004 to 2005. I don’t know if seats were involved, but the two are not compatible"
That must be it, the video I watched just said incompatible without explaining why. I assumed the differences being in the mounting points. The video did show the bottoms of the seats and they did differ in constuction. The older one, '04, had different bottom seat padding from the '05 which had foam padding.
2004 V70
