Ecm-211a - faulty signal
Zaro97
Year and Model: S60R 2004
Post by Zaro97 »
Hello , its my first thread and i hope you could help with the problem
The car has
1)loss of power and torque (low turbo pressure) 0.5 bar
2)the car at idle may got minor instantaneouslt stall suddenly and minor backfire you can hear if you are beside the exhaust
Scanning using vida it gives me
Ecm-211A Fuel Pressure - faulty signal
By checking live data
1)Fuel pressure is 400kpa at idle
2)pump duty cycle 63% sometime inc to 73% and sometimes instantaneously drop 27% and back to 60th
3) made fuel pressure sensor test (at rail) at idle its 300kpa
I think all reading are normal, anyone has explanation ?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
normal at idle but what about under load.
Zaro97
Post by Zaro97 »
jonesg wrote: 26 May 2024, 04:01 normal at idle but what about under load.
Under load pump pressure output and nominal prssure required are close to each other ..nearly the same
You can check the video i attached..you might notice somthing i didnt
VID-20240526-WA0047.mp4
(22.26 MiB) Downloaded 76 times
Live data while driving
jonesg
Post by jonesg »
maybe give more information,
is this car new to you,
did it run good previously,
have you done any work recently?
is it a new fuel pump ?
