Greetings, 1997 850 GLT (LPT) Bosch Motronic 4.4
Using a home-brew LED code reader I was able to pull multiple codes from the ECC unit, but I'm having trouble clearing the codes after reading them.
I searched the forms and was led to believe that I could clear the code after verifying that I read all the codes (twice)..
I wanted to clear the codes to see which one came right back (hard codes).
Driver side "blend door" is stuck in the "hot" position among other issues.
What is the exact procedure for resetting the ECC.
Tried holding the button down to get a "steady Light", but it just went back to showing error codes.
Using pins 13, 5, 6 on the OBD II connector.
Do all the ECC problems need to be fixed first before it will reset ??
Thanks all
Peter
Clearing ECC codes with "LED flasher unit"
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
On OBD 1 you had to read all codes before you could reset them.
Don't think you have to fix all of them.
I wonder if unhooking the battery over night could solve that issue. It won't work for SRS lights, but I think others were able to get Rid of sporadically triggered engine lights by unhooking the battery.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
What does your code reader circuit look like, specifically the type of LED and current-limiting resistor that you're using? Asking because I found that my original design with a high resistance (5000 Ohms) resistor worked for reading but not clearing codes. I switched the resistor to a lower value (500 Ohms) and was able to clear codes reliably.
viewtopic.php?t=50443&start=40
67Amazon
- Year and Model: 122S 1967
- Been thanked: 2 times
the LED code reader I used was borrowed from a friend. the LED has a built-in resister of undetermined value. I going to make myself another one with some part I had laying around. the resistance on the LED that I'm going to use measures around 26 ohms.
We'll see if changes test results.
- jreed
I haven't tried such a low value, but it seems like it could lead to a relatively high current through the LED if I'm doing my Ohm's law calculation correctly (12V / 26 Ohms = 462mA). That might blow out the LED, depending on the maximum current rating.
- 11920 Views
- 356 Views
Last post by AlanHMultiV70s
- 663 Views
- 17 Replies
- 5498 Views
Last post by shiloh51933
- 1517 Views
Last post by esl_97_850_T5
