Originally I thought I had a L front bearing going out on me - noise that a friend described as "thrumming".. Rhythmic, and being louder when the car starts moving after sitting all night. But after maybe 10 minutes of driving, the sound quiets down a bit - still there but not so loud. There is no clunking sound on acceleration / deceleration. I also felt both wheel centers, thinking a bad bearing would make more heat, but both sides were equally warm, after a round of shopping.. I lifted the car and shook the wheel, and compared it to the R side and both sides were equally tight. I do not hear clicking at full lock, so I think that rules out the outer CV joint. I don't see a center support bearing on the Left side (US Driver) drive shaft, so I guess the only thing left is the inner CV joint.
I recall that bad wheel bearings will get louder as they heat up, and get noisier, but I would like to nail down which part is causing the noise - the Axle / CV joints, or the Wheel bearing.
Ideas?
Thanks
Left front noise -- Wheel bearing or CV joints?
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Best bet is to pull the shaft and check the bearing and CV joints for roughness.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
I'm going to crawl under there and shake the shaft, too. Thanks...
Doesn't a going wheel bearing get louder from cold to road temp? This does the opposite..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Krons
Others on here have noted they run them til they growl pretty loud. Not sure every failing bearing is the same. My kids 02 S60 had a gravel’ly feeling bearing when I was doing suspension work, but made no noise. Didn’t have the part in hand at that time and I think I ran it 20k more miles before I finally replaced it.azureblue wrote: 02 Jun 2024, 14:05 I'm going to crawl under there and shake the shaft, too. Thanks...
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
azureblue
Thanks.. Good to know.. My 740 went for a while with a bad front bearing, that, like you, I found when I was doing brakes...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Sure it’s not the tire? Might get quieter as it warms up and softens.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- 863 Views
- 945 Views
Last post by jbeebo
- 2421 Views
- 2275 Views
Last post by GazmorGuri75
- 860 Views
