Hopefully I'm using terms correctly, but here goes...
The oil cooler attaches to the oil pan and has two lines that connect to the front. If you were at the front of the car and facing the engine, there is a curved/bent connection on the upper right corner. What is the name of that line that attaches to that port and what does it connect to?
I attached the best picture that I could, but I have a very bad coolant leak coming from that line.
SIde note...I just had to replace a leaking AC shrader valve. Wife says there are too many issues and I should trade it in, but I love this car!
2015XC60 Oil Cooler? Line Leak
- Has thanked: 2207 times
That looks like the transmission oil cooler line. Not sure if the line is bad or it is just an o-ring leaking and it can be replaced.
https://www.volvocarstorontoparts.ca/a/ ... 83898.html
I guessed which engine was in your car. But you can go in and change it. I don't see a replaceable seal here. Canadian $$ prices.
A leaking Shraeder valve is hardly the end of the world.
Oh, and if you look in the recent threads, you will see I am working with my Volvo mechanic friend to swap a trans in a 3013 XC60 T6 AWD for a friend as he also loves his car. It has about 190,000 miles on it and he doesn't want to get rid of it either.
- 2201 Views
Last post by fitz548
- 16 Replies
- 7184 Views
Last post by erikv11
- 1623 Views
Last post by SuperHerman
- 1533 Views
Last post by tryingbe
- 2788 Views
Last post by rguzz
