I'm experiencing a problem that I haven't seen posted elsewhere else. I've got a 1990 245 with factory A/C and the blower fan has five positions: Off - 1 - 2 - 3 - 4.
The fan now only blows when the fan switch is in the "Off" position and the A/C is turned on. If the fan switch is then moved to any of the 1, 2, 3, or 4 positions, the fan stops blowing (I know that the fan is supposed to blow in the "Off" position when the A/C is on in order to help evaporate moisture from the system so that function is normal).
When the A/C is turned off, the fan does not blow regardless of the switch position, even in "Off".
There was no rattling, buzzing, or other indication that the fan was failing prior to this failure mode. It happened while the fan was operating normally (I don't remember what speed setting it was on) with the A/C on.
All of the posts I read about the resistor pack failing say that the fan continues to run when in the 3 or 4 position, but that's not happening here. Could it still be the resistor pack? Any insights or help is appreciated!
1990 240 Blower Fan Only Works When In "OFF" Position & A/C Turned On
- Has thanked: 987 times
- Been thanked: 1075 times
I think the switch contacts may be bad or dirty. Remove, inspect and clean.
- 4887 Views
Last post by Oly850
- 1931 Views
Last post by vtl
- 1065 Views
Last post by piwikiwi
- 2082 Views
Last post by RLBOHNER38
- 1199 Views
Last post by ggleavitt
