Alternator failed 2003 XC 70, replaced with non freewheeling pulley
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
So my alternator failed yesterday on the way home from work and I got the "low battery" DTC and amber triangle, strange that I didn't get the red caption on the panel like last time it died? I checked the voltage at the battery and it was 11.6, then I checked it at the B+ terminal on the alternator and it was 11.6 as well.
I went to the auto wreckers this morning and pulled a good original that hadn't been remanufactured or anything. The only problem is that my alternator had a freewheeling pulley and the replacement either doesn't, or it does and its seized and no longer freewheels. I'm wondering if this will be a problem that I no longer have a freewheeling alternator? It's on now and appears to be working fine and pumping out 13.6 volts.
My plan is to get a new Bosch regulator and bearings and rebuild my old one and put it back on, Im wondering if the one I have on now will cause a problem?
Any ideas or advice?
Thanks.
2003 XC 70 (sold)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
i think its the signal wire terminal, not the alternator itself, otherwise the red battery warning would be lit.
the windings are getting energized.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
My alternator clutch assy grenaded years back and was towed to my local Volvo guys. They installed a rebuilt alternator with a solid pully and said that I wouldn't have any problems. That 2001 V70 T5 got totaled by someone running a red light.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Blacklab467
jonesg wrote: 10 Jun 2024, 17:03 i think its the signal wire terminal, not the alternator itself, otherwise the red battery warning would be lit.
Perhaps, I did take it apart a bit to inspect the brushes and slip rings and they are mint, I'm going to take it to an alternator shop this week and have it tested before I order parts for it and rebuild it. The field wire and terminal looked ok but I suppose it may not have been.
2003 XC 70 (sold)
