My son's first car (04 XC70) was bought running great, but using coolant due to a blown head gasket and warped head.
We fixed this and still is running great, but giving us some codes.
We rotated the engine several times and all marks line up (as well as cam locking tool). So I think that means it's in time.
Where might we look to solve this?
I should add that we also notice the oil pressure light flicker occasionally.
P0014 P0017 P0011 Timing Codes on VVT 5 Cylinder (cams over advanced and not sync'd)
The cam timing has to be reset with the VVT units clocked hard counterclockwise per the VIDA procedure
I’ll try find the link
777funk
- Year and Model: 240
- Has thanked: 11 times
I was thinking the VVT pulleys needed to be turned fully clockwise to the end of rotation (with cams locked) before the belt goes back on. Is this incorrect?abscate wrote: 11 Jun 2024, 03:43 The cam timing has to be reset with the VVT units clocked hard counterclockwise per the VIDA procedure
777funk
If I'm understanding you correctly, I may be in errror. I was under the impression that with the cams locked, the cam gears should be turned fully clockwise before the belt is put on. Is this not correct?abscate wrote: 11 Jun 2024, 03:43 The cam timing has to be reset with the VVT units clocked hard counterclockwise per the VIDA procedure
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Maybe useful viewtopic.php?t=93695&hilit=vvt&start=10
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- 3068 Views
Last post by jbkeene
- 416 Views
Last post by alvineinstein
- 23 Replies
- 1191 Views
Last post by jotoya
- 1666 Views
Last post by PIZZABYSTORMED
- 1427 Views
Last post by volvolugnut
