Automatic transmission valve body
kasualties
Year and Model: 96 850 and 02 S60 T5
Post by kasualties »
I currently have a 1996 850, and a 2002 S60 T5. The S60 does not drive (Goes into gears but forward and reverse do absolutely nothing) Would it be possible to take, A. the solonoids out of the 850 transmission and put them into the S60 to see if they are the issue. Or take, B. the valve body itself and swap it over?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I doubt it. And if the AT innyour 850 works, don't touch it if a manual swap is not in your close future. Rather try a junkyard.
1996 855 R,
2010 V70 D5,
Has thanked: 2197 times
Been thanked: 1851 times
They are different transmissions. Your 850 has a 4 speed Aisin Auto trans and your S60 has an Aisin 5 speed. You would have to do some parts checking to see if the valves are even the same.
