Hi,
I have (by the gauge) about 1/4 tank in my S70. I'm about to remove everything from the car to make way for my electric conversion, including the gas tank.
I dropped a siphon line in there with one of the rubber squeeze balls, as far as it would go down before hitting some obstruction; pumped and pumped, but only got air. When I pulled the hose ouot, the outside wasn't damp with gas.
So what's the deal? Is there an obstruction at the end of the fill tube that Volvo put there to prevent fuel theft or something, or is the level just lower than I am thinking? What is the best way to drain this thing before I remove it? I really don't want gasoline going everywhere.
Thank you.
How best to drain the fuel tank on my 99 S70?
- ThaddeusTheBold
- Year and Model: 1999 S70 T5
- Been thanked: 10 times
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
How about pull a fuel line and jumper the fuel pump relay?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- ThaddeusTheBold
Good idea
- Has thanked: 1611 times
- Been thanked: 4075 times
It’s about 15 minutes to pump about a couple gallons from the front fuel line
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Unless someone else can think of a reason, I don't see how gas would go everywhere if dropping the tank, as is. Connections are usually all at the top of the tank.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
That is true. I'd say it's a matter of weight to lower it. Is a quarter tank that heavy?
Or stick a match in there - it'll be gone in no time.
Full tank about 100 lbs/ 50 kg. Just enough to be annoying. 1/4 tank easy
- Has thanked: 987 times
- Been thanked: 1078 times
Any more than a couple gallons will slosh around and make you curse.
- 6299 Views
- 5931 Views
Last post by pedal2metal
- 2371 Views
Last post by Ozark Lee
- 1238 Views
Last post by volvolugnut
- 13 Replies
- 6243 Views
