2007 XC70 Cross Country.
A check engine light popped up a couple of evenings ago, and this just after I'd happily showed my wife how there were no warning lights lit up, unlike our other similar car...
I hooked up my lap top and Dice unit but it doesn't show me any issues dealing with the engine.
I have the usual ones relating to headlights, climate control, heated seat and similar ones.
How do I sort this out or go from here..?
How to deal with a check engine light..?
- Has thanked: 987 times
- Been thanked: 1075 times
If you have no concerns with the codes that are set, then erase them. Expect them to return sometime if you make no repairs.
AylmerQc
- Year and Model: 2007 XC70
- Has thanked: 62 times
No I don't have any problems with the codes that show up but whatever is causing the check engine light to come on doesn't show up so I can't even reset it...
Can you read Live Data with the engine running to get some idea what is happening?
AylmerQc
Is there supposed to be a tab called Live Data?
I went back to give it another go this morning with the engine running.
I do see a message saying no communications with the ECM..
I checked the fuse and it's good.
Can the car even function normally with no communications with the ecm?
I was referring to a feature of many OBD scanners to read some engine parameters while off or engine running. I do not know if Dice can do this.
AylmerQc
Just to end this for now:
I disconnected the battery for a little while then aafter reconnecting, the check engine light issue was and is still gone...
Fingers crossed...
Fingers crossed...
- 6315 Views
- 2764 Views
Last post by Georgeandkira
- 1091 Views
Last post by Fat Guy
- 21 Replies
- 4184 Views
Last post by erikv11
- 2402 Views
Last post by SonicAdventure
