Possible Incorrect Rewiring of Fuel Injection Relay?
Galaxion
- Year and Model: 1997 850
- Has thanked: 2 times
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Nope. They are both fed from the same location.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Welcome Galaxion! I've got a 97 850 wagon too and have learned a ton here about repair / maintenance / etc.
- Has thanked: 2210 times
I would suggest you check the regular stuff for rich running like:
1) Plugs (gapped to 0.028") and mileage if you have any service info. Hopefully an 850 owner can confirm that the plugs should be changed every 30k miles?
2) Distributor cap/rotor/leads? - When were those last changed?
3) O2 sensors - How old are those, in particular the front/upstream one
4) ECT /Coolant temp sensor - If this is not working or broken (check the condition of the connector where it sits on the back of the power steering pump). There are test values for resistance checking v's ambient temperature. If this is not working the car will run rich or be challenging to start when cold.
5) Check fuel pressure is around 43 psi at the rail.
Good luck with the new car!
- 23 Replies
- 3675 Views
Last post by RickHaleParker
- 3359 Views
Last post by xyznyc76
- 762 Views
Last post by shiloh51933
- 519 Views
Last post by oragex
- 49 Replies
- 10886 Views
