Question about rotating the cold side of the turbo
kllvturbo
Year and Model: 850 T5 1997
Post by kllvturbo »
Hi
Bought a new (remanufactured) Td04hl-13G turbo. Had no problems installing it. But when I started to install the oil return pipe, it turns out that the bolt holes of the pipe won't line up with the holes in CHRA. It seems that I need to rotate the cold side/CHRA just a couple of degrees for the holes to line up. So my question is: can I release the middle clamp and rotate the cold side with the CHRA just a tiny bit? Do I risk messing something up? I believe it shouldn't cause any issues with the balancing
Thanks
Twarr12000
Year and Model: 1999 S70 GLT
Has thanked: 35 times
Been thanked: 19 times
Post by Twarr12000 »
It has a pin in it. It only goes together one way.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ That is true. However I encountered one where the pin was missing, so that could be his issue.
If it is, then just make/ install a new pin.
1999 V70 GLT
kllvturbo
Post by kllvturbo »
Thanks for the info, I didn't know there was a pin. However, I didn't want to tear everything apart again so I just sliced about 0.5 mm off from the o-ring that goes into the hole in the block. That way the bolt holes lined up nicely. Problem solved, for now.
Twarr12000
The oil return line is a poor design. I bolt it to the CHRA first and stab it into the block while mounting the turbo.
