ECM fault?
Ahp
Year and Model: 2013 XC90 D5
Post by Ahp »
Hi My 2013 XC90 D5 has died while driving. Won't restart.
I had it recovered home and plugged in VIDA which had a lot of faults from battery getting drained from trying to restart. So charged battery and cleared all faults.
ECM-P003100 HO2S Heater Control Circuit Low comes up immediately (don't think this would prevent starting?)
After cranking I get additional codes:-
ECM-P200A84 Intake Manifold Runner Performance...
ECM-P200835 Intake Manifold Runner Control Circuit / Open..
ECM-P063800 Trottle Actuator Control Range/Performance
ECM-P040900 EGR Sensor
and further cranking
ECM-P020100/200/300/400/500 (all injectors open circuit faults)
I suspected in tank fuel pump - but it is not at fault - test with gauge and getting 7Bar at HP inlet.
I also notice the Swirl flap motor link was off and the motor not moving - tried spare - also not moving when switch on ignition.
I have got her to fire with Easy Start but does not run with out.
I have metered out the cables to ECM and all are good.
12V and GND to ECM all good
Vida shows following readings when cranking
ECM Fuel Pressure : 7690 kPa
ECM Fuel Pressure, nom value : 357670 hPa
ECM current through fuel pressure reg : 9ma - This is very low
ECM Metering unit MPROP output duty cycle : 95%
I bought a S/H rail to try plug in a reg valve to see if I can get more than 9mA - but not change
It looks like I am getting the correct high pressure to the rail but seems the injectors are not firing........
Why are all these other sensors throwing faults??
I am suspecting my ECM is at fault - any thoughts?
HELP
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Not many Diesel Volvos in US. Maybe when UK and Europe wake up tomorrow they will have some answers.
Has your ECM ever had water leaked on it to cause contact corrosion?
Ahp
Post by Ahp »
No evidence of water ingress and plugs and connectors spotlessly clean (no corrosion) on ECM. Strange how it instantly died while driving with no symptoms leading up to that point.
wxp73
Year and Model: V70 T5 2001
Has thanked: 1 time
Post by wxp73 »
Check all fuses in engine compartment.
Ahp
Post by Ahp »
Update. I had my ecm cloned in to a second hand ecm. Fitted the replacement and it fired up first turn of the key.
:D
