Suddenly won't start, just sputters. 2002 S60 Topic is solved
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 12 times
Been thanked: 5 times
Post by 850TurboTurtle »
I drove it 60 miles yesterday. Today when I went to start it up it gave a first sputter, then stalled after 1-2 seconds. Then it refused to start at all, except for an occasional sputter when first cranking. Plenty of cranking power on a new battery. No previous problems of any kind on this car.
I bled the Schrader valve on the fuel rail - didn't appear to have any bubbles. I have over 1/8 tank of gas, nothing new from what I drove on yesterday. Weather hasn't changed: still mild and pleasant.
So - the possibilities I can think of are: clogged fuel filter, water in the fuel, bad injector, bad computer, or punk rock demons mad at my smooth jazz summer CD collection.
I don't know how to get the codes on this since I can't get to the Autozone down the street.
Any suggestions or things to try next?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Did it fire up this morning after letting it sit overnight? This happened to me when i flooded my engine after doing a PCV job. Does it sound like the starter is engaging ?
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
850TurboTurtle wrote: 23 Jun 2024, 21:30 I drove it 60 miles yesterday. Today when I went to start it up it gave a first sputter, then stalled after 1-2 seconds. Then it refused to start at all, except for an occasional sputter when first cranking. Plenty of cranking power on a new battery. No previous problems of any kind on this car.
unplug the maf and try again.
850TurboTurtle
br0dy519 wrote: 24 Jun 2024, 10:33 Did it fire up this morning after letting it sit overnight?
No joy. The starter is engaging and turning nice and fast with a battery that's only a few months old. I checked spark and we have that. I'm thinking fuel pump or filter has failed?
850TurboTurtle
I did a OBD code check and it had no codes. Any ideas on how to check fuel delivery rate?
jonesg
Post by jonesg »
read pressure with vida , other scanner or a pressure gauge at the rail.
which model/yr car is this.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
850TurboTurtle wrote: 23 Jun 2024, 21:30 I bled the Schrader valve on the fuel rail - didn't appear to have any bubbles.
I recently replaced my fuel pressure sensor on my 08 S60, was a lot of fuel pressure at the rail, six paper towels soaked with fuel. Agree with checking pressure via a scan tool. Fuel filter isn’t terribly expensive, I’d suspect fuel pump…assuming pressure is low.
08 C702.5T (sold)
The non-Swedes:
850TurboTurtle
I popped in a new mehle fuel filter in about ten minutes. Started right up, seems to drive well. I’ll report back if anything changes in the next few days.
But it looks like a $25 fix.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
850TurboTurtle wrote: 27 Jun 2024, 22:40 I popped in a new mehle fuel filter in about ten minutes. Started right up, seems to drive well. I’ll report back if anything changes in the next few days.
Interesting that it went from all to none. I was going to suggest ETM yesterday but I kept getting auto logged out. Have replaced very few fuel filters over the years and never had one go out so good to know. If I ever have a no start situation will have to check the pressure rather than just seeing fuel from the Shraeder valve.
Krons
Post by Krons »
Good result. I’ve changed the fuel filter as first step of ownership on my three P2s, one for sure picked up a little power, and good maintenance to do on these cars.
08 C702.5T (sold)
The non-Swedes:
